Old 07-02-2017, 07:45 PM   #6
Numbrseven   Numbrseven is offline
Numbrseven's Avatar
Mine had the same problem when brand new and it was the carb. The dealer said the mfr puts some kind of coating in the gas tank and it comes off and plugs the jets in the carb. It doesn't take much junk to plug a jet. Mine had sealed screws so I could not take it apart to clean it. I replaced it and it ran fine again. My new carb does have the screws so I can take it apart and clean it should the issue arise again. If you can take the carb apart to clean it, I'd do that because it's essentially no cost but 30 minutes total time. If you have to buy a new carb, they're only like $20.
