Old 08-03-2017, 05:31 PM   #10
Dan, I'm sure that's also how you corrected wiring issues before they became trouble.
That would be correct sir. I wouldn't really call them issues, but I definitely wasn't a fan of how some of the wiring was routed, so I put them to "Dan spec"
Originally Posted by Sochin View Post
Dan, I'm at 3300 feet here in Montana. I bought the 10 jet kit for the VM26 Mikuni. Carb (new one) goes on tonight, so far I've blue loctited every shock, wheel nut, on the tripple clamp. New oil and NGK Irdium spark plug put in. Replaced front fork oil with Yamalube 15w. Going to finish it up tonight with new japanese made 428 chain and JT sprokets 17 and 44, need to get more blue locktite and black zip ties to clean up electric wiring and cables.
Sounds like you are doing what I did with mine, mods right out of the box.
Being at 3300ft on a stock bike, a 105 or maybe even a 102.5 main jet might be the ticket. The 102.5 won't come in the kit, but if you decide to delve into fine tuning the carb you can order a genuine Mikuni jet through Jetsrus.com. I highly recommend genuine jets. I bought the same jet kit you did and had nothing but issues trying to get my bike dialed in, and had inconsistent threads as well as one jet that was blocked with debris.
As far as the pilot jet, the 20 size that comes in the VM26 clones should work ok for you at that elevation, but will still likely be a little lean. A 22.5 or 25 would be just about perfect for your elevation. You are roughly 2500ft higher than I am and I have found a 27.5 to be the right size on my modified bike, with the 25 being a hair lean. The general rule of thumb with Mikuni jetting is a half a jet size for every 2500ft change or 25 degree difference in temp. Since nobody wants to re-jet all the time for temperature changes, we primarily focus on elevation lol. My method for temp changes has always been to set the fueling up for cooler weather (50-60 derees), so when it gets hot the fueling will be a hair richer and help the motor run cooler.
Needle position on the Mikuni tends to be center or 1 slot down from center/4th slot down from the top.
I really do suggest some "half step" jets if you really want to get that carb dialed in. Taking the time to really dial in the carburetor will give you the best of both worlds. The best performance AND fuel economy. I still average mid 60mpg with mixed riding and a heavy hand.
Mikuni Jet numbers for the clone carburetor.
Main: N100.604 - https://jetsrus.com/a_jets_by_carbur...arge_round.htm
Pilot: VM28/486 - https://jetsrus.com/a_jets_by_carbur...-486_pilot.htm
Last little point to touch on that you will likely run into with the 17/44 gearing and an otherwise stock bike is that your top speed will never change, but your bikes cruise speed at half throttle will be higher. My 17/43 sprockets on a stock bike had a part throttle cruise speed around 50-55mph. It could do this all day long without ever breaking a sweat, but would have to be pegged wide open to do 60, and 62 was the fastest the bike would ever muster. Once I did the exhaust and intake and got the carb tuned again, I can cruise 60 all day long, never needing beyond half to 3/4 throttle unless I hit a steeper hill. Top speed is around 66-67mph, and I have a current max of 71 going down slight a hill...which is scary on such a tall light bike with knobby tires.
