Old 11-25-2017, 12:21 PM   #1
Angus67   Angus67 is offline
Angus67's Avatar
Idle mix stack up
So i cleaned out my pz27 carb on my 200gy, got it all back together, but when i put the idle mix scew back in, i only had the screw. So i put it in, 2 turns out
Now that it back on the motor and full of gas, a small drop forms on the mix screw. Most other carbs I’ve worked on has a small spring and rubber (?) washer.
I may have blown it into another dimension with 150psi of air.
Just to confirm. Its oring , spring, mix screw?
Could this also cause hunting idle? The rubber carb mount is pretty cracked up, so that is more likely the issue there.
2006 roketa 200cc
1971 Yamaha xs650
2x 1980 xs650, 1 is a café, other is a chopper/brat
1972 Honda xl250
2x early 90's Honda rf600 parts bikes
more mc junk laying around.
