Old 05-12-2020, 04:23 AM   #59
Originally Posted by Bulldogg1984 View Post
With the help of the group I figured out how to install the back shock. Im 6' and 195-200. Once I got the shock on Im now on my toes hahaha. I assume this may break in and sit down further......hopefully?
If you got one of the 1200lb rate spring shocks like we did, you are probably going to need to dial out some preload on that rear shock. I weigh a good 70lbs more than you and I had to actually dial back the preload as it was set from the factory it came from to get my rider sag right. That should help a little with the tippy toe situation.
