Old 05-23-2020, 08:11 PM   #2
I'm not Canadian, but if you can get your hands on a Venhill kit you could always build your own. Just need to be able to solder one of the ends on. Kit U01-1-100-BK should do the trick.
Otherwise, you could give Venom Motorsports a call as they are based on both sides of the border. They might be able to help sort you out with a clutch cable that would work.
