Old 12-01-2020, 11:17 PM   #14
goJimH   goJimH is offline
Originally Posted by Walt28Wood View Post
I really hope someone can point me in the right direction. I have a 2019 Apollo Enduro 250 and it seems even replacing the factory battery with an interstate battery and once a month I have to charge it because it starts getting weak. Is there an aftermarket stator or something to boost the charging system?
I would do what Duck9191 Said - plus others here. If you cant get your bike to maintain say 12.7 volts or higher at the battery while at say 3000 rpms then you had better consider other options.
In addition to that - I would check all my connections, grounds, ect.. and make sure they are secure. Next - I would test for a parasitic drain on the battery with the bike off.
Best of Luck
2020 Lifan X-Pect - VIN # 157
JTF1264.17 Front Sprocket
Learning as I go - Trying to get cost of my education down!
