Old 03-31-2021, 09:06 AM   #5
Deckard_Cain   Deckard_Cain is offline
Only 1 O-ring, which is in the one in the picture is required. That location is where the main oil feed to the head goes through the cylinder and head area to get to the rocker cover where it drains down on the valves and rocker assembly.
If you want to get a new O-ring, you can use Honda part number 91301-200-000 or locate a nitrile rubber O ring 10mm x 1.6mm at your local parts/hardware store.
Since that is the only location oil can leak from, I would personally replace said O-ring just to be safe as it may have a crack or nick in it causing oil to seep past. I bought a 5 pack just to have extras on hand because I take my bike apart so much lol.
As far as only having 3 dowels, that is also normal. You could order another one and use it, but realistically speaking it isn't necessary.
If you are going to store it without the head on, it would be a good idea to at least cover the jug with a bag or cloth to keep dirt and other junk from getting into the rings.
I recall CSC techs telling many of us when we install the tt250 metal shim HG that the O-ring is not required- is that only when junking the stock MLS gasket?
Because I've been running the thinner HG for a good while now and no o-ring. lol.
-Jason.
