Originally Posted by John Holifield
I essentially have the same exact problems with my DLX with the exception that my error code is P0505.
Have you found a solution to it idling rough and running lean?
No. Still idles like crap when cold. It doesn't stall like it did when new. I'm just living with the poor cold running for now.
I did find the check engine light problem - the wire plug was quite loose.
