Originally Posted by Aufgeblassen
In order for fuel to fully fill the carb, AIR must be removed. The cranking eventually removed the air so engine could run.
As stated before the carb is gravity fed. The bowl is vented so air is removed as the bowl is filled. But the again you could of have a stuck float which didn't allow the bowl to fill at the time. You got it running so no need for anything else to be discussed.
