the way the signal works is there is a small piece of metel in the relay that heats up and breaks "or makes" contact to create the blink. if you are running a bulb that has a different power draw than the stock ones you will have this problem.
either find out how much power your drawing from the stock bulbs and match that,
or find yourself A relay that the new bulbs will heat up with.
IMO replace the signals and housing altogather the stock ones look really hookie and add a lot of chees to the bikes apperance. I got a nice set of turn signals off ebay for about 20 bucks. and they are sexy!
