Old 05-21-2022, 01:23 PM   #2
65cabriolet   65cabriolet is offline
65cabriolet's Avatar
I cut all the way across the cat on mine and cleaned it out, then used the swedged part of a tailpipe extension to connect the 2 pipes. welded it to the head pipe. I then mounted the headpipe on the exhaust and fit the rest of the pipe to the bike and tacked the pipes to each other. Then removed the pipe from the bike and finished both welds... turned out pretty good and was real easy to maintain the curves of the exhaust.
