Originally Posted by Nutcracker
I completed the 14 tooth front sprocket. Same as others have mentioned I ground .05 to .06 Inch's casing. There's a lip on the casing tightly enclosing the 13 tooth factory sprocket. Any way you look at it your grinding and decreasing tolerance.
Can you post photos of the grinding mod?
