Old 11-27-2022, 10:38 PM   #5
Originally Posted by WindMindMusic View Post
72mm head diameter in this product, but fitment is my next question. Time to check out the Zongshen 250cc Head bolt pattern info.
72mm Cylinder Bore Top End Piston Gasket Set Replacement Kit for Cfmoto 250cc Honda Helix CN250 JMstar 250 https://a.co/d/1R1Qmmr
Yes. You have a 72mm diameter head. Those kits for ZS167 (67mm, 14hp) don't apply to your engine.
The water cooled engines have different frame mounting points. BEST option if you want to increase HP is head work. I have no leads for porting. I did buy a dremel kit to do it myself, but haen't had the time.
If you hear about anyone adapting a different motor to the frame, please share. You have the ZS172FMM-3A engine. It is awesome!!!!!
