Old 01-16-2023, 06:51 PM   #11
Zooker89's Avatar
Try looking at the other end of the circuit. If the electric starter motor circuit activates when voltage is applied across either brake control to brake light circuit then you just need to find where it feeds off to sensor, or relay and cut that out of the brake circuit and feed a constant voltage to it from the key turned on circuit.
Good to know. not there yet, but may need (want) it
