Old 01-20-2023, 08:53 PM   #3
Fast_Freddy   Fast_Freddy is offline
Fast_Freddy's Avatar
Originally Posted by knwilson View Post
What's your elevation if you don't mind? I am installing a Nibbi 30mm this weekend.
It comes with the following:
1 x Slow Jet
Available Size #40
3 x Power Jet
Available Size: #120 122 125
https://www.chinariders.net/images/smilies/nod2.gif
I'm at 1400' - Was thinking about starting with the #120 and #40...
I'm at 450' ASL. My carb is 28mm and I expect a 30mm carb would need more fuel. I would probably start at 42 and 125 (FWIW). You might be okay with the 40 if you go 2-3 turns out on the idle mixture. GL
22 Templar 250
