Originally Posted by Chienmin Su
This is the first time I adjust a carb on bike. I adjust the one with red circle for idle speed fast/slow, is it correct? The engine ran a little lean, can I adjust the screw in blue circle to change air/fuel mixture. It's in a weird angle to stick a straight flathead screw driver and is very tight. Should I use a right-angled screw driver to turn it? Thanks again!
Frank,
Here is information on the idle adjustment screw. It sets the slide height inside the tower on the carb
https://www.chinariders.net/showpost...80&postcount=6
The black plastic sheath on the spark plug wire is on the outside of the sparkplug wire. It is just some additional insulation. That is normal. It is not physically attached to the spark plug wire... just over it.
And here are a couple of posts on the carburetor and some other ifo on valves.
https://www.chinariders.net/showpost...59&postcount=4
These posts are from the Templar resource thread at the top of the Dual Sport/Enduro section
