Originally Posted by bigdano711
Agreed on the EFI, these bikes aren't quite ready for that. To me, simpler is better, and carburetor is about as simple as it gets. They could offer a carb'ed version with those sweet forks, tho...
DLX forks? Those are not inverted forkes. Hawk is just overpriced compared to base Templar, or any Templar for that matter.
If you are 5'6 to 5'10 with 30" or less inseam, the CGclones might work better for you. Also, if you really need your heels planted and not so balanced on a motorcycle, the enduro class is not for you.
BUT...As I said, you can lower the Templar by drilling a new lower rear shock mount hole. And you can slip the front forks up an inch to lower the front end too. This is indeed documented on this website.
