Thread: Templar X 250
Old 03-17-2024, 07:37 PM   #1658
So any word on replacement wheel bearings for the Templars?
Took my rear off to (finally) install my 40 tooth sprocket and both rear bearings are shot. Fronts are sounding suspect too…
Edit-so mine were seized solid on each side of the rear wheel.
Pounded one side out and to my surprise 2 bearings came out, and 2 from the other side as well.
Minus the one that was destroyed in the process, once removed from the bike all are flawless working bearings. They were just crammed in so tight the pinched each other.
All 4 are “61905RS 010 C&U 01A03” so replacing them should be easy.
Only question is why 2 per side?
