Going to check from the stator later today...
The easiest way to check for spark from the stator is to:
1. Turn the key OFF
2. Unplug the stator plug from the harness
3. Remove the spark plug
4. Attach the test light clip to the black/red wire connector coming out of the engine
5. "jump" the big starter solenoid terminals with a screwdriver to turn the engine over briefly. Hold the test light probe to an engine bolt at the same time. If the test light lights up, the source coil of the stator is working fine.
