Not sure it was bent. The brake pedal on Honda CR's and KTMs are tucked in real tight to avoid trapping stems between the lever and the frames while riding. But fortunately, you can bend it to virtually any position, then set the height as well with the adjuster on the piston. Totally customizable. It is rather important that you can easily press that pedal with workboots on!
