If your getting fluid spillage when you bleed then good, if not keep bleeding till it spills, my bike has a bolt just above the brake lever close to my foot peg, when I loosen it it it pushes the brake lever down some, you can loosen it until your pistons are out far enough for your brake to work.not sure this helps? good luck!
