Old 03-27-2009, 01:23 PM   #44
AZ200cc   AZ200cc is offline
So it happens at the same high rpm in every gear? or only 5th :? ..You checked everything I would check, Except the petock to see if it might be slightly restricted or maybe an even better flowing air filter. Not sure what You have now. But if it only happens in fifth I have no clue why. A restriction should occur in all gears at the same rpm range :?
<br />2001 Suzuki DR200SE<br />1997 Suzuki RM250 YIKES<br />1995 Yamaha Breeze 125 daughters<br />1991 Honda XR80r Restored<br />maybe a 2003 Yamaha TTR90
