tao tao parts diagram
I am currently rebuilding the gearbox portion of my atv-125 semi auto. i cannot find what i would describe as an idler gear for the main and counter shafts(came loose inside gearbox and got damaged). What is the preferred place to find parts? preferably with diagrams. I will probably be looking for help assembling eventually but I'll start a thread when it comes to that point.
gearbox
hello... where are you??? this is a lot of work,,, you mean the drive gears that are inside the motor to drive the gear for the chain to go to the rear wheel.... right..
the gears are for the transmission main and countershaft. there is one small gear with a bearing clipped into it. The lone gear on the left came loose and now has a flat portion. Even some kind of teardown manual may help if it will show me the proper name of the gear.
