10-29-2016, 01:36 AM | #1 |
stripped my hub installing new rear sprocket
So I went ahead and got the new (flat, non-dished) 47 tooth rear sprocket for my TT250 and decided to install it tonight. Due to the flat sprocket you need to use .300 shims behind the sprocket to space it out to the distance of the stock, dished sprocket.
I didn't realize when I re-installed it that I would be losing .300 of purchase of the 10mm bolt threads on the shaft of the bolt, due to the shim thickness, which left about .310 of bolt sticking into the hole (which, by the way is 1.270 deep). I over-torqued the bolts when re-installing them and stripped all of the four 10mm holes out. So my thought is to get a 10x1.25 tap and clean up the first .310 of compromised threads and then buy four new bolts with enough length to take advantage of the existing 1.270 deep threaded holes and screw them down (and hope they hold). Does anyone have any better ideas or input before I tackle this tomorrow? |
10-29-2016, 02:12 AM | #2 |
If you have no luck with the longer bolts...
tap the 10mm holes to 9/16" is 11mm... drill the sprocket holes... ...
10-29-2016, 02:14 AM | #3 |
Yeah, I figured I could do that if necessary but I do not have a mill and want to avoid drilling off center if I can avoid it. Thanks.
10-29-2016, 03:05 AM | #4 |
most lightly wouldn't have to drill the hole out...
run the tap straight into the striped hole.. .
09 XT660R ... 06 TTR250 ... 80 Montesa H6 125 Enduro... 77 Montesa Cota 348 MRR "Malcom Rathnell Replica"... Current resto projects.. 81 Honda CT110... 80 Kawasaki KL250A1... 11 Husaburg TE125 enduro... "sold" along with another 31... Lifan 125 Pitbike.. "stolen" ... KIWI BIKER FORUM...... http://www.kiwibiker.co.nz/forums/content.php All the best offroad rides in NZ... http://www.remotemoto.com/ E-mail... xtpete1@gmail.com Last edited by pete; 10-29-2016 at 04:18 PM. |
