Old 04-12-2017, 09:29 PM   #1
mckayprod   mckayprod is offline
Rear brake pads
Here's a question I haven't seen addressed on the forum: Will the CSC replacement rear brake pads fit all known rear brake calipers? I have a single piston caliper...the CSC Service Tutorial for brake service states that both front and rear calipers are dual piston. So, do I have an oddball bike, or do both brakes take the same pads, or am I imagining things? I have to replace the pads because they have completely worn out (down to the backing. Eeek!) at 8500 miles. Surprisingly, the noise wasn't too bad and I didn't notice any problem with the braking power. The CSC pads are on the way, so I'll post an update soon enough. Comments?
Old 04-12-2017, 09:45 PM   #2
As I recall, my RX3 rear caliper is a single piston design. With that said, I'm amazed that you have worn out your rear pads at 8500 miles. In over 50 years of motorcycle riding I have never worn out a set of rear pads. Good on you for realizing that your rear pads were worn out. I use the front brake for 90% of my stopping power, except in cases where the 'road' surface is less stable. In my experience the rear brake will get one in serious trouble if it is the primary braking source on a normal roadway. My RX3 will lock up the rear brake in a heartbreak, too much excitement for me.
Peter Y.
Old 04-12-2017, 11:30 PM   #3
Jay In Milpitas's Avatar
Had to go out to the garage to confirm that mine has a single piston rear after reading this and subsequently checking the CSC tutorial. Must have been either used on the 15" wheel or a production change.
http://www.cscmotorcycles.com/v/vspf...age_%20(8).jpg
Horse holder at Madame Orr's House.
Old 04-13-2017, 12:02 AM   #4
humanbeing's Avatar
https://item.taobao.com/item.htm?id=524277319218 Rx3 rear had 3 types!!!
Old 04-13-2017, 01:12 AM   #5
rjmorel   rjmorel is offline
rjmorel's Avatar
FYI, I had CSC replace my rear pads after the Baja trip last month with 14,100 miles on them. Where pretty far gone but still had a little life in them, rj
Live Zong, and Prosper
Old 04-13-2017, 09:49 AM   #6
Looks like the caliper varied during the production run. I trust CSC to send me the right part. I was surprised at the accelerated wear...I think the piston may not have fully retracted and the brakes were dragging. Together with the lousy weather I've been riding in, and all the crud flung up from the road, that could have ground 'em down some.
Old 04-13-2017, 08:44 PM   #7
Check your rear brake linkage to be sure it has free play and isn't causing the caliper to drag during normal riding. Mine wasn't dragging, but I loosened it up a bit more, just personal preference.
Old 04-14-2017, 10:15 PM   #8
So here's what the pads look like:
Pretty wiped out. I'll check the linkage and keep an eye on them.
Old 04-15-2017, 04:55 PM   #9
I bought some of the stock, rear brake pads from Taobao, but as soon as I use up my supply, I am switching to sintered brake pads for the rear, as well as the front brake.
Rear Brake Pads: EBC FA496
The RX3 motorcycles imported to the United States by CSC have the latest, rear brake caliper. The U.S. bikes use the EBC FA496 brake pads employed by the following Japanese motorcycles.
Honda CBR250R, CBR300R, CB300F, CBR650F
Suzuki GW250, SFV650
http://www.chinariders.net/showthread.php?t=15532
Old 04-15-2017, 06:46 PM   #10
humanbeing's Avatar
Originally Posted by SpudRider View Post
...Suzuki GW250....
69100-48820 http://item.taobao.com/item.htm?id=540531884782
Trustworthy chinese product
大力 (based in Guangzhou) Dali-H07 http://item.taobao.com/item.htm?id=43752843317
HT (same maker as stock Zongshen Sierra) SF627FF https://item.taobao.com/item.htm?id=534646071207
Old 04-15-2017, 10:06 PM   #11
fjmartin   fjmartin is offline
Hey Spud, I find the rear brake to be a bit to "on or off" than I'd like. Especially when offroad or wet roads. Do you think a sintered brake pad would help with that? Thanks!
2017 BMW F800GS Adventure
Old 04-16-2017, 02:07 AM   #12
I don't know for sure, but it certainly wouldn't hurt to give the sintered brake pads a try. The sintered brake pads are a modest investment, and you can always switch back to the stock brake pads if you don't like the results you get from the sintered brake pads.
I haven't experimented with the sintered brake pads on my rear wheel, yet. However, my rear brake works much better after I made two modifications. The first mod was the installation of the Progressive shock absorber. The second mod which improved the modulation of the rear brake was restoring the original wheel geometry with a 21-inch front wheel.
