Hawk with Mikuni Help
OK so trying to get this carb tuned and just would like a consensus of what i might need.
First off i have done the following; Air box mod w/K&N filter, upgraded exhaust,new iridium plug, and a mikuni with a 115 main and 25 slow, idle mix turned almost 2 turns due to mods, at 1 1/2 turns it didnt seem right. I have followed similar set ups for the mods i have. i am also at 650ish elevation. The issue i am getting is at idle when i blip the throttle just a bit it stalls, now if i roll on the throttle its fine? is my idle jet too small? should i go to a 27.5 or 30? is my main too small? go up to a 120? All input is appreciated.
2017 Hawk 250 1998 Harley Dyna |
You might need a 27.5. Did you raise the needle? If you haven't, try raising it one notch first and see if that helps.
2025 Lifan KPT 400 2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 (Sold) 2016 Black Hawk 250 (sold) 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel |
#3 | |
I just didnt know what i missed as i researched and try to set up the mikuni according to similar mods and found that the 115/25 was common. Looks like each is its own beast...
#4 | |
#5 | |
This is why I always tell people to get a range of jet sizes for both main and pilot.
#6 | |
You shouldn't need anything larger than a 30.
I'm in agreement with the other guys on a 27.5 slow jet. That said, have you tried moving the clip up one notch? Does it get better or worse? It's a quick and free experiment.
That's actually a great point that I overlooked. The needle in the 5th notch might be making the jet transition too rich, so when you quickly blip it the bike just bogs out.
Just remember to make sure the bike is fully up to temp before making any calls on jetting changes. Go take it for a solid 5 to 10 minute ride and then see how it runs.
