01-25-2019, 07:08 AM | #1 |
Was to easy...
The 1980 KL250 rebuild/restore was going well...
then this... this is the first of 4 sections I have to remove... and the dam metal is only 1mm thick... Be a real bastard to get it painted... decals on to have it start to leak a few months down the track.. .
09 XT660R ... 06 TTR250 ... 80 Montesa H6 125 Enduro... 77 Montesa Cota 348 MRR "Malcom Rathnell Replica"... Current resto projects.. 81 Honda CT110... 80 Kawasaki KL250A1... 11 Husaburg TE125 enduro... "sold" along with another 31... Lifan 125 Pitbike.. "stolen" ... KIWI BIKER FORUM...... http://www.kiwibiker.co.nz/forums/content.php All the best offroad rides in NZ... http://www.remotemoto.com/ E-mail... xtpete1@gmail.com Last edited by pete; 01-25-2019 at 08:17 AM. |
01-25-2019, 01:53 PM | #2 |
After you weld in another 1mm piece, have you considered laying another strip over that? I have an old XT350 tank I'm doing that to; it'll have an armored look when I'm done, and hopefully take twice as long to rust through again.
01-25-2019, 04:48 PM | #4 |
I put a 2mm patch on the inside with a 10mm overlap..
weld a long bolt to the patch centre to hold it in place.. I just run the mig around it... I done the welds vertical down fast weld and keeps the heat down.. all the rust pitted areas I am going to flow body solder over.. ..
01-26-2019, 01:49 PM | #5 | |
01-26-2019, 03:36 PM | #6 |
Yes.. pretty sure it would be the same thing or that close it doesn't really matter..
not very common these days.... wonder where to get it.. A question for Mr Google I think .. Just found this online... ..
01-26-2019, 05:03 PM | #7 |
You can generally get body solder in two flavors. The traditional lead based, or the "safer" high tin type that requires a bit more heat.
Hawk Information and Resource guide: http://www.chinariders.net/showthread.php?t=20331 2018 Hawk 250 - Full Mod list here. http://www.chinariders.net/showpost....62&postcount=1 2024 Royal Enfield Shotgun 650 https://chinariders.net/showthread.php?t=34124 Last edited by Megadan; 01-27-2019 at 01:54 PM. |
