Gotta love the quality
Just hit 90 miles and this happens
What is that long broken bolt from?
Looks like it was a little loose and was "torqued/twisted/pressed down on" in a funny way to break at the threads like that... Seen something similar on my 1999 Kawasaki KLR 650 when I upgraded the Frame Bolts ![]() ![]()
#3 | |
Yea, got me that way too,...
BD125-15 |
At least it's not the axel!
Electrician & Electronics Tech 2014 Honda CB500XA 2016 CSC TT250 1976 Honda CJ360T 2022 Honda Navi |
Thinking about doing that. How Is it holding up?
I must be lucky, I got 300 miles and haven't had them break (yet). I replaced both axle bolts with Grom bolts.
2018 BD125-8-x21rs ZS190/Genuine PE28 Kepspeed GP1 Exhaust Protaper se x110 bars/grips 1/4 MotionPro throttle Kepspeed Braced swingarm Chimera rear hub assy Grom Intergrated tail light Superlite Sprockets 17/32 custom made from Japan Chimera Swing Arm Bolt RK MXZ Chain #420 All Balls wheel bearings Motodynamic fender eliminator Coremoto ss brake lines Composimo 2.5 lower link Grom Calipers-w/ebc pads/rotors Michelin tire 140&120 13x4/13x7 fatties Grom forks |
On my old enduros, I would upgrade with True Value bolts and nuts. I am guessing the Grom bolt route would be your best bet.
It's crazy because today was the only day I've been able to ride due to fuel problem and not break down. They bike was running great because I installed a carb this past weekend. Now the engine bolt. I can't say I'm mad, as I was waiting for it to happen. I have class 10 bolts that was recommended by a user on here, but I think I'm just going to make the mounting holes on the engine bigger and use grom bolts. All the other vital bolts on bike a from a grom so I might as well do the mount bolts too.
#14 |
I replaced the bolts on my Hellcat and haven't had any issues ...yet. I think a good solution would be to weld a doubler plate or a bushing on the outside of the mounting holes so that the load on the bolts would be spread across a wider area. You'd have to use a longer bolt of course.
#15 |
The bolts break due to the heavy amount of vibrations from the 125cc engine. Apparently the 190cc does not vibrate as much.
Drilling out the engine casing works. Or run the Class 10.9 (Grade 8 equivalent) or go with Class 12.9 (higher than grade 8). |
