Old 12-09-2018, 09:23 PM   #1
Angus67   Angus67 is offline
Angus67's Avatar
Wireing in a starter relay.
So I have a 107cc quad. I can get it to run and runs great.
I found the wires from the starter button and I have a starter relay from a old ford car. When I hook up the yellow/red wire to the relay , and ground the relay, and push the button, I get nothing. The relay doesnt click over. The relay is new. I chose the relay because it's a system I know, or a at least taught I did. Should I see 12 volts on that yellow red? The button shows continuity.
I'm considering a heavy duty push button to just jump the starter over without a relay. Any harm in that? No relay, just momentary button to push the starter?
Maybe point me to a wiring diagram?
It says alpine on the stator cover.
107 pz19 carb.
2006 roketa 200cc
1971 Yamaha xs650
2x 1980 xs650, 1 is a café, other is a chopper/brat
1972 Honda xl250
2x early 90's Honda rf600 parts bikes
more mc junk laying around.
Old 12-10-2018, 08:19 AM   #2
dirtbkr188's Avatar
Did you try testing the relay with a 12V battery, to make sure the relay is working? Just because it's new doesn't necessarily mean it works.
There's a wide variety of relays HERE for you to find the correct replacement for your quad.
Also make sure it isn't the starter button that is bad
Old 12-10-2018, 09:37 AM   #3
NzBrakelathes's Avatar
Check you have 12v at the black wire on the plug with yellow/red
Are you gettin 12v at yellow red at relay end? Is the ground good?
It’s jyst a relay n basic
Battery ok?
Old 12-10-2018, 02:18 PM   #4
Angus67's Avatar
Battery is new and out of my 1987 honda shadow.
The start button shows continuity thru the wires
I did get the relay to click over so it's ok
I'll check voltages tonight
Thanks guys
2006 roketa 200cc
1971 Yamaha xs650
1972 Honda xl250
Old 12-10-2018, 09:44 PM   #5
Angus67's Avatar
Ok. The black wire is getting intermittent 12v. Were do I connect that black wire once I trace down the break in wire causing intermittent 12v? The yellow red goes to the relay correct? There is a green wire grind on other side of starter button. Were does that go? The black wire looks like it goes to the headlight switch.
2006 roketa 200cc
1971 Yamaha xs650
1972 Honda xl250
