Old 04-18-2019, 12:21 AM   #1
madwolfcody   madwolfcody is offline
can some one post a link of a mikuni carbby
I have a Apollo pz30 and want to upgrade to a mikuni carb but cant find one that looks legit
Old 04-18-2019, 12:22 AM   #2
its a Apollo 250cc delux
Old 04-18-2019, 12:27 AM   #3
tarote9025   tarote9025 is offline
This is the mikuni clone i got. I just use real jets from mikuni amd have had zero issue with the carb itself
https://www.amazon.com/gp/aw/d/B07CN...b_b_asin_image
Old 04-18-2019, 01:26 AM   #4
I have the pz30 right now is that a mikuni
Old 04-18-2019, 06:10 AM   #5
Ski_rush   Ski_rush is offline
That’s the exact carb I bought. Seems to work so far. Can you also help with a link to where you got the pilot jet? I think I got the name right. The longer jet, the slow jet. I bought a set of pilot jets on Amazon, but they were completely the wrong size and didn’t fit. I had to return them. The main jet set I bought was great, but I’d appreciate a link to the slow jet. Thanks.
Old 04-18-2019, 08:43 AM   #6
Pilot Jet
https://jetsrus.com/a_jets_by_carbur...-486_pilot.htm
Also main jet, if you want to buy genuine jets and not mess around with the cheap jets that are either mislabled or incorrectly sized.
https://jetsrus.com/a_jets_by_carbur...arge_round.htm
Old 04-18-2019, 10:49 AM   #7
Yep, love the little Mikuni. Have them on everything (- RX3's). Makes jetting easy and they run superb.
Old 04-18-2019, 12:23 PM   #8
DualSport   DualSport is offline
If you want a Chinese fake that says Mikuni on the stem and Japan by the bowl search B07CN36W65 on Amazon.. $29.00
That's as close as you'll get to a real Mikuni that is 30mm with 48mm stud holes..
There is actually a real one that has a polished body and plunger choke, but it's extremely hard to find.. I don't know if it's because it's old OEM or what. This is why mine is still rocking a PZ30..
You can also replace the airbox and use a 48mm intake adapter and use any Mikuni you want.
Old 04-18-2019, 12:38 PM   #9
The_DJ_Remixer   The_DJ_Remixer is offline
Can you guys post a link to a thread for Pilot jet sizes that are working with the knock off mikuni carb, 120 main, and performance exhaust? Much appreciated!
Old 04-18-2019, 01:56 PM   #10
Heres the pilot jet 25 i got
https://www.amazon.com/gp/aw/d/B06XS...b_b_asin_title
Main jet 115
https://www.amazon.com/gp/aw/d/B00RR...b_b_asin_title
Exhaust
https://www.amazon.com/gp/aw/d/B01DO...b_b_asin_title
Megadan put the part numbers you should be looking for if you want different sizes of each jets just wanted to show different places to get your hands on them
Old 04-18-2019, 02:02 PM   #11
most common working pilot sizes are 25, 27.5, and 30.
Main jet sizes range from 105 to 115 for most bikes. depending on mods.
The best combo for an otherwise stock bike is a 25 and a 105.
As with all jetting, there are many factors at play so these are not set in stone and your bike and area may require adjustments from there.
Old 04-18-2019, 07:03 PM   #12
appreciate it guys I just am trying to figure out if I have a mikuni carb right not its the pz30 carb and the one on the amazon listing says pz30 in the title so does that mean I have that one already
Old 04-18-2019, 07:07 PM   #13
Easiest way to identify the Mikuni clone is the 4 bowl screws vs. the 3 on the PZ30 carbs.
Unless you get a mutant hybrid like my PZ30B (pumper) which says Mikuni on the carb body and has the centered carb bore like a mikuni, has 3 bowl screws like a PZ30, takes the odd ball pilot like the stock pz30 carb but uses Mikuni main jets.
Gotta love stuff from China.
Old 04-18-2019, 07:46 PM   #14
NzBrakelathes's Avatar
https://www.ebay.com/itm/Hawk-250-Ke...s/303077495104
The Mikuni IMO realy isn't an upgrade of much
Look at this set as it isn't expensive and has a lot of stuff in it.
Old 04-18-2019, 09:15 PM   #15
Not much of an upgrade outside of full tuning capability on all jets and port matched to the intake. Unless you magically found a set of pilot jets instead of a drill bit that only gives you one size option, which is then not reversible if it happens to be too big.
