Old 08-19-2018, 09:59 PM   #1
DeseanM   DeseanM is offline
Doh! TaoTao HELLCAT 125 speedometer From KMH TO MPH?
Hey what’s up Chinese riderrrsss.... quick question for you guys I just recently purchased a hellcat 125 and I have the slightest idea on how to change it from kmh to mph on the speedometer have tried everything maybe I’m missing something help a brotha out! 🤔🤔🤔
Old 08-20-2018, 01:11 AM   #2
Chinabike   Chinabike is offline
I just pressed the left button till a section started flashing. Then set with the right button.
Old 08-20-2018, 01:17 AM   #3
try this.
Old 08-31-2018, 11:47 AM   #4
Chromehead22   Chromehead22 is offline
Have been trying to find this out as well. I have tried the above, but no dice. Some have said the Hellcat will not switch over to MPH from KMH, but I have seen several online pics of Hellcats that do read in MPH. Anyone that has actually got it to work on a Hellcat??
Old 08-31-2018, 12:23 PM   #5
imapdog   imapdog is offline
imapdog's Avatar
prob have to buy new cluster. this is usually common early bird shipments on new bikes and atv's. this run of hellcats must be new allotment for the dealers and they ordered wrong ones, and prob whole allotment is this way....once you get the mph one it will most likely read 6mph faster than gps mph
Old 08-31-2018, 04:50 PM   #6
Yes. 2017. But think they missed up the 2018.
What imapdog said below.
Old 09-01-2018, 02:38 PM   #7
I believe federal law for DOT/EPA certified bikes, they MUST be in MPH. I doubt you guys will get recourse, as opposed to paying out of pocket, but perhaps putting some pressure on the dealer might help.
Old 09-01-2018, 11:50 PM   #8
It seems to be a problem in the 2018’s. I am going to ask the dealer about it (familygokarts) as if they are selling To US customers, it seems it should have the option to register in MPH. On the start up sequence it will show a MPH on the cluster (along with everything else) but after the sequence it goes to the KPH setting and cannot be switched that I can tell.
Old 09-03-2018, 01:17 AM   #9
ShiftDX   ShiftDX is offline
ShiftDX's Avatar
Hey guys, new guy here.
I also just picked up a Hellcat two weeks ago myself, and with the same issue. My speedometer lights up and right to KPH. Tried everything to get it to mph. Basically we have to replace with these with a better speedometer?
Old 09-03-2018, 09:54 PM   #10
Not a very beautiful solution, but I would just use one of my old cell phones (no sim) and load a speedo app on it. They are plentiful in the app store and way way more accurate than any china bike or Japanese bike speedo. Get a mount off of ebay and your golden.
Old 09-04-2018, 08:03 PM   #11
My 2018 Gen2 Vader does read in MPH and not KPH, but that said according to my cellphone app and also running it alongside other vehicles and comparing MPH readings, it is laughably inaccurate.Still ,if you run it alongside someone and find out what your 3 most common legal speed limits are on your speedo and memorize what that shows as on your bike, that will almost always get you by, it ain't like your in serious danger of breaking any speed limits if you find out what 25,35, 45 are .
2001 Mustang GT
2004 Sportster
2018 VADER
2020 Orion RXB250L
Old 09-04-2018, 08:28 PM   #12
Thats good advice. I do same.
Old 09-04-2018, 08:45 PM   #13
Just swap the speedometer out to one that you can calibrate
Like this one. Samdo Motorcycle Digital Odometer Speedometer Tachometer KMH MPH 14000RPM Gear Dirt MotorBike 1,2,4 Cylinder https://www.amazon.com/dp/B01LYK10Q2..._gKYJBbM2V5SSN
Old 09-04-2018, 10:30 PM   #14
ShiftDX's Avatar
Grin
Good call JerryHawk, going to order one of these Friday and see if anything changes, worst case I can always send it back.
2003 Buell blast
2014 Tao Tao Lancer 150 (modded to the gills)
2018 Tao Tao Hellcat 125
Old 09-05-2018, 08:00 AM   #15
This one has the gear indicators and turn signal. and looks Identical to the stock speedo. https://www.amazon.com/dp/B0716TGCRT...d_i=B0716TGCRT
125cc, hellcat, speedometer, tao tao
