Oil Screen?
Is it possible to not have a screen/filter? I've combed my owner's manual, and it says nothing about filters or screens. Just says to change oil in dusty conditions. Wah? ---- Model LF200GY-5
Look about 7 posts down. Yes, you have a screen. It's on the left engine case, bottom, towards the front, next to the shifter. 24 mm chrome cap. Don't lose the spring.
hey...
Don't tell me what to do. I'll throw that spring down the toilet just to spite you.----LOL----Thanks I saw that post but couldn't figure it out. I think it might be time to clean my screen out.
I think Bruce mentioned using the bottom plug, because if you are not quick and eagle-eyed, the spring will shoot out the side plug with the oil without you realizing it! I knew it was there, so (barely) saw it plunging with the oil, and then had to sort through the discarded oil to locate it. Just a little easier to drain the oil from the bottom, and then open the side up to clean the filter.
I tend to keep some pressure on the cap while letting the oil drain some then remove the cap and the spring tends to stick to the cap while you pull it out.
Allen
This definately helps...
this is my first bike and wanna keep it in good shape. If you guys didn't help it would prolly be screwed up by now. thanx guys
Not a problem. The oil change is really easy and since oil is pretty cheap change it often. You don't need to use expensive motorcycle oils either. The shell rotella T 15w40 works good. I have valvoline maxlife in mine. Others have there favorites. Just make sure you get one that does not say energy conserving and you should be fine.
Allen
#8 | |
I usually ride a couple of miles before the oil change too. I let it cool down while I get all the tools and drain pan ready. Use a pair of gloves or a shop rag to hold it works too.
Allen
Allen, I was meaning to ask you how the Duro tires are working. I have a Median rear I bought last Fall, but haven't needed to change it out yet. Are they holding up well? My stocker has 2000 miles on it and looks like it'll be bald by 3000.
#11 | |
Red, I have about 1500 miles on the rear and it still looks new. I just put the front on last week. They are great on the street and still have some dirt abilty.
I give the a recommendation. My stock rear made it to about 3400 miles. Allen
