Old 04-14-2018, 12:27 AM   #1
rider55   rider55 is offline
Resistor spark plug or non-resistor plug cap
Hi,
My question is going from a NGK spark plug (resistor plug)or(non-resistor plug), do you replace the resistor cap with a different cap?
On Hawk 250
Thank's
Old 04-14-2018, 12:55 AM   #2
If you go with a non-resistor spark plug then it would be a good idea to have a resistor cap on the system. The resistance is there to reduce the thermal load on the coil and also increase the spark duration. I personally prefer to simply stick with a resistor plug, but you can easily switch to an NGK plug cap. I run an XD05F cap on my Hawk, which helps raise the plug wire away from the exhaust as well as shortens it up a good 6 inches. I run a resistor plug, so I removed the resistor from the cap itself and replaced it with a plug of copper. http://chinariders.net/showpost.php?...3&postcount=51
Here is said cap installed.
http://chinariders.net/showpost.php?...4&postcount=52
Old 04-14-2018, 01:11 AM   #3
Hi,
So I have to have at least non-resistor spark plug or spark plug cap.
Your saying both cant be non-resistor .
How to tell if my plug cap is a non-resistor.
Thank's
Old 04-14-2018, 02:09 AM   #4
Originally Posted by rider55 View Post
Hi,
Thank's
The stock Hawk setup is a standard cap with a resistor plug.
If you want to run a non resistor plug, then you will want a resistor cap.
You could run with a non resistor plug with a standard cap, sure. Who knows, it may work fine. Sometimes the resistors are simply used to help reduce electronic noise interference on many modern bikes.
It could also cause idle problems, misfires, run-on, power dips through the rev range, and even poor ignition as a whole. This has a lot to do with the coil and it's own internal resistances. In some extreme cases, the lack of at least one resistor in the ignition circuit can cause the coil to overheat and eventually fail. In the world of old-school bikes, which is basically what these bikes are designed off of, the coils had a higher internal resistance, and needed the plug and cap resistance to slow the discharge rate. In some cases the total ignition system could have over 50,000 ohms of resistance end to end.
This slowing down of spark discharge is part of the reason that eliminating all resistance can potentially cause running issues. The spark actually fires too quickly for the ignition event, and causes the previously mentioned issues.
That said, I haven't tested the coil that comes on these bikes to know if they need said resistance, but you could always try a non resistance plug on the stock cap and see how it goes. The coils are cheap anyway, so if it does fail, no biggie.
That said, if you are thinking to do this as some sort of performance improvement. I can tell you now that, even if you can successfully run without any resistor in the system, it won't make a lick of difference.
Old 04-14-2018, 02:22 AM   #5
Hi,
Thank's for replying.
I'm running a NKG DR8EA plug and the R makes it a resistor plug? I think.
How to check the plug cap to find out if it is a resistor type,because the cap has been changed.
Thank,s
Old 04-14-2018, 02:24 AM   #6
Hi,
The R means it is a resistor plug, yes. You are fine. That is the same plug I am using.
Old 04-14-2018, 02:32 AM   #7
Hi
So the plug cap has to have ohms 5k or more.
Thank's
Old 04-14-2018, 04:32 AM   #8
Hi
Thank's
If you want to run a non resistor plug, then the cap should be 5k ohms. Your Resistor plug is also around 5k ohms.
Old 04-14-2018, 09:21 AM   #9
roundhouse   roundhouse is offline
roundhouse's Avatar
Interesting, I had no idea. I am sure I have a resistor plug but I will check it next time I ride. Thanks
Old 04-15-2018, 03:53 AM   #10
Thumbs Up
Hi,
Thank's Megadan
That makes sense.
Thank's
Old 02-17-2022, 03:02 AM   #11
Skateforlife6   Skateforlife6 is offline
So this may be stupid but if both resistor cap and plug are 5k ohms, does that make them both together 10k. Is that okay or is it to much resistance? Should it only be one or the other?
Old 02-17-2022, 07:41 AM   #12
One or the other and not both.
