Old 10-24-2022, 04:24 PM   #1
tigerjacopo   tigerjacopo is offline
progcdi
hi folks,
i found an interesting programable cdi on the web.. bus digit progcdi: it a black box with orange lettera and a couple 2led digit..
could be programed in many aspect without a pc.. but to set the advance needs an info.. someone knows this value : “In "Pu" introduces a physical position of the crankshaft position sensor.
This is the angle between the pulse from the sensor and the upper position of the piston. This is normally from 20 to 30 degrees.” ?????
Engine is a 169fmm
Old 10-25-2022, 09:02 AM   #2
I googled "bus digit progcdi" and got nothing
Got a link or character string from the post/ad "on the web"?
Originally Posted by tigerjacopo View Post
hi folks,
Engine is a 169fmm
Old 10-25-2022, 02:51 PM   #3
ebay link
https://www.ebay.co.uk/itm/133516010...mis&media=COPY
Old 10-26-2022, 02:43 PM   #4
ghostdancing   ghostdancing is offline
Pu is the pick up position in degree..you must measure with degree wheel how many degree before tdc the thoot on the flywheel meets the pick up ....it s called the static advance
