Old 01-19-2023, 09:50 PM   #1
knwilson   knwilson is offline
Question Templar 250X Fuel Filter
Turns out I am still leaking gas. Best I can tell, it’s coming from the fuel filter. Anyone know what I need or have a link for a replacement? Going to try swapping to NIBBI 30mm this weekend and will do the fuel filter then as well.
Old 01-19-2023, 09:54 PM   #2
TominMO   TominMO is offline
Is it the filter itself or maybe just clamps that are not tight enough?
2021 Lifan Xpect--sold
2022 Lifan KPX
1972 Honda CT90--The Carrot
1969 Honda CT90--The Tomahto
Old 01-19-2023, 10:44 PM   #3
Hap   Hap is offline
If the filter itself is cracked. I’m sure most any similar sized inline filter will be fine. Most aftermarket’s will probably be better than what’s on it.
22 Templar X 250
Hand Guards
Custom Graphics
Pro Taper Grips
125 main 45 pilot jets
42 tooth rear sprocket
2010 Yamaha Vstar 1100 Silver Star
Old 01-20-2023, 03:24 AM   #4
I am thinking my filter could be causing surging (vacuum?). I sealed the intake manifold, which seemed to help quite a bit. But yes, any good generic inline filter should do.
Old 01-20-2023, 10:22 AM   #5
Hap   Hap is offline
It’s definitely possible. Does it go from normal idle to higher and then back down. And does that back and forth?
22 Templar X 250
Hand Guards
Custom Graphics
Pro Taper Grips
Old 01-20-2023, 10:39 AM   #6
I ordered a Tusk In-Line Fuel Filter:
*Fits with standard ¼” fuel line between the fuel tank and carburetor
Clear housing design
1” sintered bronze filter
Dimensions: 7/8” x 2 ¼”
I also reached out to XPRO and they are sending me a replacement as well under the parts warranty. If the Tusk fits, I'll use it. Not sure yet if it's the filter or just loose connections, etc... I also have a 30mm Nibbi arriving tomorrow. Fingers crossed I can finally get this thing running properly with these next steps. Otherwise, I will dig into the valves...
Old 01-20-2023, 12:32 PM   #7
severely   severely is offline
I also reached out to XPRO and they are sending me a replacement as well under the parts warranty. If the Tusk fits, I'll use it. Not sure yet if it's the filter or just loose connections, etc... I also have a 30mm Nibbin arriving tomorrow. Fingers crossed I can finally get this thing running properly with these next steps. Otherwise, I will dig into the valves...
Why not adjust the valves while you wait on parts?
Old 01-20-2023, 01:01 PM   #8
No real reason other than lack of confidence in my own mechanical skills. Hate to tear into the engine if I don't have to. I have adjusted valves before on an old Honda Trail 90 I have, but did so with a detailed video walking me through all the steps. I have not been able to find one for the Templar so I am bit nervous to tackle it if it might not be necessary.
Old 01-20-2023, 05:04 PM   #9
Hap   Hap is offline
What are the steps in finding Top Dead Center on the Templar X? That’s the only part of the process that I can’t seem to find.
22 Templar X 250
Hand Guards
Custom Graphics
Pro Taper Grips
Old 01-20-2023, 05:18 PM   #10
There’s a mark on the flywheel.
Old 01-20-2023, 06:25 PM   #11
See post #24 in this thread. Different bike but same ideas.
https://www.chinariders.net/showthre...t=31297&page=2
2022 Lifan KPX
