Old 05-25-2008, 03:03 PM   #1
Frog   Frog is offline
main jet internal diameters
Hi
I am wanting to up jet and read in a post about reaming the original.
I have a good set of very fine drills but does anyone know of a cross reference for main jet size and the diameter of the hole? I'm looking to start aiming for a 105 and maybe move up from there.
Anyone any thoughts?
Cheers
Frog
Old 05-25-2008, 04:00 PM   #2
CRidin   CRidin is offline
If you have a dial caliper. You can find a drill that is 1.05. Thats also how You can do it with the tip cleaners.
Old 05-25-2008, 08:42 PM   #3
warrior91   warrior91 is offline
Yes acetylene torch tip files are cheap and come usually with a tip cleaner/ hole diameter chart stamped in the lid... :wink:
Also for interests sake you could google a conversion chart for machinists that cross reference hole size mm/inch fractions/thousands and letter size drill bits.
'91 Yamaha Warrior- stage 2
'83 Honda ATC 70
'08 Yongjiang 125cc mx (Loncin)
'08 Yongjiang 150cc atv (Jinlong)
Old 05-25-2008, 08:46 PM   #4
Ok , here ...
http://www.engineersedge.com/drill_sizes.htm
Handy hole chart. and good place to look around...at least for me :roll:
'83 Honda ATC 70
Old 05-26-2008, 12:44 AM   #5
ejcycles   ejcycles is offline
ejcycles's Avatar
Be careful, not all Main Jet Sizes Correspond with Drill Sizes!!!
Thanks, Bruce @ Endless Journey Cycles
"Phone Calls Only" ~330-274-0098~
Hours: Tue.-Fri. 10:00-6:00 Sat. 10:00-4:00 EST.
Dealer for: Lifan, Crossrunner ATVs.
http://www.endlessjourneycycles.net
Old 05-26-2008, 12:46 AM   #6
So what would they corespond with if not mm? All may not be measured in mm but all I have seen are.
Old 05-26-2008, 12:53 AM   #7
ejcycles's Avatar
If you look at a #115 jet from a Mikuni verses a Keihin carburetor the sizes are not the same at all... there is a big difference. So no, not all jet sizes correspond with drill sizes.
Old 05-26-2008, 01:06 AM   #8
I stand corrected. Mikuni does use a different indexing number. However on these bikes and most others I have built the mm does match up. Here is the screwed up way Mikuni gets thier numbers.
http://www.ozebook.com/compendium/t500_files/mikuni.pdf
Old 05-26-2008, 09:02 AM   #9
Thanks everyone - I'll let you know how I get on!
regards
Frog
Old 05-26-2008, 09:42 AM   #10
red2003   red2003 is offline
I am the one who used the torch tip cleaners to ream my main out. I found the cleaner (file) that just fit into the jet and reamed the next size up, then the next size after that. The torch tip cleaners work well, but it's a slow process and a painful one on the fingers. I would try the files before the drill. It's not hard to mess up drilling something so small and your margin of error isn't very big. When I reamed out my main you couldn't even tell I had done anything by looking at the hole, but it made a BIG difference in the way it ran.
Old 05-26-2008, 09:48 AM   #11
Red any chance you could put a dial caliper on the cleaner you used? Inthese jets they will measure in mm. Or it could be coincidence.
