Old 01-13-2024, 02:29 PM   #1
solidsnake2431   solidsnake2431 is offline
Head Scratching Supermoto wheels for Templar X?
Hi! I am looking to put supermoto wheels on my '23 Templar X pro. The Honda CRF 250L wheels are the same measurements for the sprockets and they appear to be the same for the wheel spacers and axle but I am not sure about this part. Is the axle bolt and spacers the same as well?
Thanks!
Old 01-15-2024, 03:34 PM   #2
Really!? Nobody on here knows the answer to this simple question? 🤔
Old 01-15-2024, 04:23 PM   #3
Without someone having both bikes to verify, it will be hard for someone to answer.
Old 01-15-2024, 04:57 PM   #4
My front axel, front seals/bearings on my Templar appear to be identical to a ~20 year old Honda CRF 250 (by dimensions, haven't purchased or tested). So axels have the same diameter on the 20 year old CRF, I think.
But I don't know about the newer models listed as compatible on the nice looking wheels you posted (CRF250L 2013-2020, etc).
You also have to match the axel spacers on each side to the forks and the swingarm legs, and you have to match the offset for the disk rotors (both wheels) and sprocket mounting. Those are also wider wheels, for wider tires. You need to find tires compatible with those wheels that fit in the swingarm on the Templar...
You need either all of those measurements, or buy them and compare them. Then post the results here, please!
Old 01-15-2024, 06:19 PM   #5
The brake rotors and sprockets are the same mounting pattern and measurements..
The axle style and spacers appear to be identical but this is the only thing I have not been able to measure. This would be sick as hell if they fit. The Templar X Pro I have is orange and black. It looks better then ANY other bike I have ever seen and I have had them all (Jap OR China!) With SM wheels it would look beyond incredible..
Old 01-15-2024, 06:22 PM   #6
DO IT
Keep them clean if you need to return, but I agree. SICK!
Old 01-26-2024, 09:40 PM   #7
DasEnduro   DasEnduro is offline
If you do it and it works I’m going to buy these same wheels.
