Old 07-23-2008, 11:25 PM   #1
naqviak   naqviak is offline
LB200V - Brake setting...
I changed front brake caliper (under warranty) and now wondering how to make sure my brakes are operating propely. Should they lock front tire when I press lever full (as they don't)? or not?
Also, I changed rear sprocket and again wondering if my rear brakes are adjusted properly. What shall I look for?
Thanks in advance.
Old 07-24-2008, 12:29 AM   #2
ChiGongJitsu   ChiGongJitsu is offline
my bikes do, if they don't you don't have full stopping power
not sure how to adjust brakes though, there is probably a ton of information on the internet that you could apply to your brakes, as the adjustments are probably pretty much standard
Old 07-27-2008, 02:10 PM   #3
liverchip   liverchip is offline
Send a message via MSN to liverchip
If they're disc brakes, they're self adjusting. If they're not locking,then there's more than likely air in the system and they're in need of bleeding.
2009 XR650L Big Red Pig
Tusk bar risers
2007 X-Moto(Jetmoto) GY250
--mods---
15/40 sprockets
UNI Pod Filter
2007 Shineray TMS 200XYi--Betsy
Betsy Mods:______________________
Acerbis DHH headlight
FMF Powercore pipe
Uni Pod Filter
Old 08-03-2008, 01:16 AM   #4
Qingdao   Qingdao is offline
For that back brake put your bike on the wheel stand, spin the back tire, and press the pedal with your hand. You should be able to stop the wheel with just your hand.
<div><a href="http://www.youtube.com/watch?v=X2ilH...s</a></div><br />
