Old 01-27-2009, 07:46 PM   #1
rocketaj   rocketaj is offline
50 cc pit bike china bike
:roll: hay my pit bike starts and runs but after like 10 sec it stols is it the carb or the seals or what please help
Old 01-28-2009, 07:33 AM   #2
winwun   winwun is offline
Need a little more info to really make a judgement.
When it stops, does it stop suddenly, or does it start missing, get worse, and then stop ?
When you re-start it, does it start easily, full choke -- no choke ?
Does it have fresh gas -- with/without ethanol.?
Are you in a cold climate ?
If everyone picked up a couple of pieces of litter, pretty soon there wouldn't be ANY, and wouldn't THAT be nice ?
Luke, 11: 21
Old 01-28-2009, 09:43 AM   #3
IronFist   IronFist is offline
Could be your gas cap seal or petcock or crud in the carb. It could be a lot of things. Fresh gas and trying to run the bike without a gas cap would be my first set of checks. Then drain the bowl to make sure you are getting gas to the carb. Do you have a voltmeter to check your battery?
Gas and spark are the first things to look for IMHO.
IronFist
___________________________________
The "chain" of command is used for beating spammers.
Old 01-28-2009, 11:02 AM   #4
no im in fl i have fresh gas i ran it with no gas it revs high and then stops like it will run i can rev it up and like after 10 sec it will stol and if i they to give it gas it will bog i cleaned my carb i did it wont start off choke and it wont run off choke im ordering a knew carb and some other stuff thank you
Old 01-28-2009, 11:10 AM   #5
katoranger's Avatar
Sounds like you are not getting any gas. Most likely a plugged up jet. Make sure gas is getting to the carb from the tank too.
I had a stuck float on my 125 after it sat for a few weeks. The carb was new too. Only about 3 hours on it.
Allen
Old 01-28-2009, 11:45 AM   #6
DDG1976   DDG1976 is offline
Send a message via Yahoo to DDG1976
I'm with Ironfist, I'd try to run the bike without the gas cap and see if that helps. It might just be a plugged up vent in the cap.
I have all of soberday to satur up!!
Old 01-28-2009, 12:04 PM   #7
ejcycles   ejcycles is offline
ejcycles's Avatar
Sounds like Another plugged Pilot Jet...................... and or maybe not running an air filter.
Thanks, Bruce @ Endless Journey Cycles
"Phone Calls Only" ~330-274-0098~
Hours: Tue.-Fri. 10:00-6:00 Sat. 10:00-4:00 EST.
Dealer for: Lifan, Crossrunner ATVs.
http://www.endlessjourneycycles.net
Old 01-28-2009, 02:13 PM   #8
katoranger's Avatar
The two pitbikes I bought had some incredibly worthless airfilters. They would not have kept marbles out.
Allen
Old 01-28-2009, 02:22 PM   #9
hay when i took my carb apart there is two jets 1 is the idil jet one is the what not the main jet but the jets in the middle before i cleaned the idil jet it was cloged are they both post to be open like i can see thrue the jet im just wondering
Old 01-28-2009, 02:30 PM   #10
ejcycles's Avatar
Yes you are supposed to be able to see through them... I hope you didn't run a drill bit through the pilot jet, that could ruin the size it's supposed to be. Same with the main jet.
Old 01-28-2009, 08:45 PM   #11
no i did not run a drill but i took a nedle and dryed to clean it out but i still cloged oooooooo well im geting a new one
