Old 02-21-2008, 07:47 PM   #1
johnroketa200   johnroketa200 is offline
Sprocket not engaging rear wheel..
ok, need some help...went on a ride today..and at a stop sign I shiften down to 1st gear and then the sprocket wouldnt engage the rear wheel..it just spun and I didnt go anywhere? any ideas whats wrong and how to fix it? thanks!
Old 02-21-2008, 07:52 PM   #2
liverchip   liverchip is offline
Send a message via MSN to liverchip
Are you saying that chain was spinning and the rear wheel wasn't turning or that the clutch was out and no go, no chain movement, just the motor running.
2009 XR650L Big Red Pig
Tusk bar risers
2007 X-Moto(Jetmoto) GY250
--mods---
15/40 sprockets
UNI Pod Filter
2007 Shineray TMS 200XYi--Betsy
Betsy Mods:______________________
Acerbis DHH headlight
FMF Powercore pipe
Uni Pod Filter
Old 02-21-2008, 07:54 PM   #3
yes chain was spinning, rear wheel not moving..
Old 02-21-2008, 07:55 PM   #4
katoranger's Avatar
Sounds like possibly the sprocket bolts have sheared.
Allen
Old 02-21-2008, 08:01 PM   #5
how it that possible, the bike only has 34 miles on it and it appears those are lock nuts..and I wasnt riding it hard...
Old 02-21-2008, 08:15 PM   #6
A picture is worth a thousand words. Post a photo if you can. Did you get the bike at a dealer?
Tusk bar risers
--mods---
15/40 sprockets
UNI Pod Filter
FMF Powercore pipe
Uni Pod Filter
Old 02-21-2008, 08:17 PM   #7
no bought it used...but a pic doesnt show anything, I dont have the rear wheel off yet, It just happend today...so are there bolts underneath the sproket that hold it to the hub? its so weird...the sproket still feels tight to the hub when I try to move it with my hand..
Old 02-21-2008, 08:29 PM   #8
katoranger's Avatar
That is strange. Some of us have experience failure of the hubs, but not at 34 miles.
Fatboy250 has some custom parts in his hub after finding them loose.
Allen
Old 02-21-2008, 08:44 PM   #9
Q   Q is offline
If it's like the Lifan, the sprocket isn't really bolted to the hub. Instead it is held in place by a big snap ring. What looks like bolts are actually studs that fit into rubber buffers in the hub.
Q
Old 02-21-2008, 10:10 PM   #10
Q, u were right...all four of those posts were shredded off...seems kinda cheesy how it stays on...so u are really relying on that snap ring..one of the posts is stuck in the hub, and three have the nuts on the other side of the sprocket still..ugghh. is there a better way to attach it? where do I get those studs from? and is there a better rear hub/wheel/sproket setup tht someone else has used? and what size do I look for? thanks!
