Old 06-26-2010, 02:43 PM   #1
turbocat   turbocat is offline
Help please shineray xy200st 11 gearbox clonking
Hi All
Iam new to quads so here goes
When Iam letting my clutch out to pull away I get a clonking noise and very jerky But once you are going its all ok .All the chain and alinement is good Ive had my dad run next to me and its defo jerking in the engine end.
Anyhelp would be fantastic
Old 06-27-2010, 01:07 AM   #2
katoranger's Avatar
Are all the motor mounts good? Check for broken mounts and bolts. Make sure they are all tight.
Also what type of oil are you using?
Allen
Old 06-27-2010, 04:36 AM   #3
Not sure what oil is in but all the mounts are good mate
Old 06-28-2010, 01:54 AM   #4
samuelpaul11   samuelpaul11 is offline
I think that If You have used cross chain then It had been occurred grunching voice. So You will have to check it. You will check the front derailleur to see if the chain is rubbing. It should just clear the inside of the cage on the frame side. I hope that It could be helpful.
8gb usb flash
Old 06-28-2010, 04:56 PM   #5
It seems like its the gearbox but not 100% sure any other help It only does it on the biting point.
