Old 09-16-2010, 07:08 PM   #1
david805   david805 is offline
HELP! SSR 110
ok got my son a SSR 110, delivered today.
I put it all together and changed the oil.
I started it BUT is seems the throttle is stuck wide open! HELP
Think its a Carb issue? I tried screwing the idle screw in and out but nothing changed.
1996 350cc Yamaha Warrior (mine)
2006 150cc BMS Coolster (daughter's)
2007 125cc Hensum & 2010 SSR 110 Pit Bike (son's)
Old 09-16-2010, 08:18 PM   #2
waynev   waynev is offline
Unscrew the top off the carb, the odds are that the slide was put in backwards ( theres a pin in the carb body and a slot down one side of the slide to line it up ), when installed backwards the slide will not go down all the way as it gets stuck on that pin and holds it near wide open, you should pull the air filter off to verify it is working properly before starting again, also while the air filter is off make sure you oil it, either with K&N air filter oil if it;s the cotton pleated type or Foam air filter oil if it's a foam filter.
Old 09-16-2010, 09:53 PM   #3
ok found the problem the MORONs had the carb bowl 180 degree wrong.
I took a video:
So I flipped it around:
Amazingly it works great now!
Old 09-16-2010, 10:04 PM   #4
That's a new one! I can't figure out how the idle would rev so high with a backwards bowl. Major vacuum leak maybe?
Old 09-17-2010, 12:22 AM   #5
Probably, I was really freaking out ............
Old 09-17-2010, 01:30 AM   #6
I didn't mean you had a vacuum leak, I meant the carb.
BTW, it's time to update your sig to include your son's new SSR 110.
Old 09-17-2010, 08:36 AM   #7
Cal25   Cal25 is offline
First time to see that one. Glad you figured it out quickly.
Old 09-17-2010, 09:45 AM   #8
Image how freaked out I was when I started it and it was WOT and smoke started coming out of the manifold.
8O
