Thread Tools Display Modes
Old 11-28-2022, 01:00 AM   #1
Twills   Twills is offline
Thumbs Up Brozz Recon Success!
Over Thanksgiving I finally got my Recon put together. It took about 8 hours with minimal help and hand tools, and started right away. The engine sounds smooth and quiet.
Coming from riding a CRF 230, this bike seems heavier, wider, and higher. Next, I'm going to lower it a few inches with a 280mm shock, and perhaps change the front sprocket to a 15 or lower. Would a 13 be excessively low? It's only going to be used on dirt, and the stock gearing feels unreasonably high for low speed trail riding.
One small issue is I habitually drain the carb on bikes when done riding. Is there an easy way to get to the drain screw on the 2022 Recon? It was a little difficult to get a flathead past the exhaust heat shield.
Old 11-28-2022, 05:38 AM   #2
Zapkin   Zapkin is offline
Zapkin's Avatar
that is a nice looking bike! i like that color.
Old 11-28-2022, 07:37 AM   #3
Nice!
Old 11-28-2022, 11:31 AM   #4
Heavier - Check
Wider - Check
Taller- ???
How come most Crf 230 i have seen and rode were higher than most of the hawesque motorcycles.
Be glad that you could drain the carb, 99% of the times those little bolts are stuck like they are weld to the bowl.
brozz, dirt, gearing, lowering
