HI Bird QH 250 GY 250cc
Need info on the wright size pulley puller and need info on how to set cam and flywheel timing chain , as I think it jumped time as the chain tension was never used to keep chain tension. So I need a diagram on how to set timing.
It's a Honda clone I just don't know what Honda engine. ![]() Last edited by kc5bdb; 11-18-2014 at 02:53 PM. Reason: Add Year of Bike |
Please show us pics of the motor, and we'll go from there.
Weld is the expert on these.
Very kind of you, but it's definitely HB who is the expert.
#6 | |
Put the cam bolts back in, and then remove the two chrome screw covers on the left side engine cover. Insert a socket through the center hole, and rotate the engine counter-clockwise until a T appears in the upper hole. There is a line next to the T, and it must line up with a notch in the viewing hole. When it lines up, the horizontal lines on the cam sprocket will line up with the valve cover mounting surface. If it does, everything is happy. Does it seem like there isn't enough cam chain tension?
For reference, I believe the Hi Bird bikes were Lifan related. I think Hi Bird might have actually been a subcontractor of sorts for Lifan--some of their bikes looked identical, and their old website kind of referenced a connection. My guess is the engine is related, or an actual, 223cc Lifan. I bet Humanbeing can confirm or correct me on this...
#8 | |
It is closely related to the Honda XR200 / XR230, but the cylinder stud spacing is larger on your engine. That changes everything in the top end. There is a ton of parts available for your engine on www.taobao.com; just search for CB250.
