Old 07-24-2017, 09:00 PM   #1
green_hawk250   green_hawk250 is offline
Hawk Seat Rebuild
After lowering the Hawk it was the time to take care about the seat. I don't know who designs seats like this? Do they have anything between theirs legs, or it is designed by women for women? I think about that on every bump on the road when hitting the tank with my balls.
So, there were two options, either remove the bulge or fill up the cavity. I decided to remove the bulge first, and check. Here are the steps:
Before:
The foam is taken out.
The foam to be removed.
Coarse fiber sanding disc used for shaping and cutting the foam.
Smoothing the surface with sandpaper.
Vinyl is back.
And after
Once done, I found modified seat pretty comfortable to my taste. What a difference!
Note: It is not shown on the picture, but I strongly suggest to add the polyester batting under the vinyl, as in the following example.
For those, who want to reconstruct the seat by adding more foam, here is experience with my
Versys-X 300.
Before:
Stock vinyl removed
Reshaped two layers of 2 inches foam ordered here: http://www.foamforyou.com/Open_Cell_Foam.htm
Topped with polyester batting from Hobby Lobby.
My wife added these. Made from marine grade vinyl, also from Hobby Lobby.
And the final view. Now I am in heaven!
Please also check my another mods:
http://www.chinariders.net/showpost.php?p=241532&postcount=1
http://www.chinariders.net/showpost.php?p=241533&postcount=2
http://www.chinariders.net/showpost.php?p=242310&postcount=8
http://www.chinariders.net/showpost.php?p=243629&postcount=10
http://www.chinariders.net/showpost.php?p=247652&postcount=13
http://www.chinariders.net/showpost.php?p=248489&postcount=4
Old 07-24-2017, 10:21 PM   #2
jfeliciano15   jfeliciano15 is offline
Great post Green Hawk
That is exactly the info I needed to get rid of that annoying rear half of my Hawk seat.
Thanks!
Old 07-25-2017, 12:07 AM   #3
That K aw seat is pretty hard when I checked it out at the dealer. Ok for shorts, but can see where it would be tough for an extended jaunt.
Taking China rider principles and applying to jap bikes. Your supposed to order the high dollar replacement seat said the gate keeper.
Old 07-25-2017, 12:43 AM   #4
Hell, compared to my GL, my hawk is like sitting on a sofa suspended by clouds. I do wish the foam was a lot firmer thpugh. After an hour on the thing my rear end is sore.
Old 07-25-2017, 05:47 AM   #5
old kid   old kid is offline
old kid's Avatar
that looks great, nice job
Old 07-25-2017, 02:12 PM   #6
JeremyC   JeremyC is offline
I was looking at my seat awhile back, and wondered how they stapled that vynil cover on. Got any pics of that process?
Old 07-25-2017, 03:25 PM   #7
jimwildman   jimwildman is offline
jimwildman's Avatar
Short staples and a staple gun, rust proof staples would be a wise choice as regular staples will eventually rust.
long staples will wind up poking you in the inseam. I forget the proper length but i have a box left over from snowmobile seats.
Old 07-25-2017, 04:04 PM   #8
Nice job. I would like to do something similar. Like move the notch about 2-3" farther back. I fill like I'm sitting on the tank.
Old 07-25-2017, 10:05 PM   #9
1. Don't use manual stapler. It is not powerful enough. This is the one 20 gauge stapler from Harbor Tools I used.
2. Use minimal possible air pressure or the staple would punch a hole in the vinyl. I used 65 PSI.
Old 07-26-2017, 09:59 AM   #10
jimwildman's Avatar
That might be best, I hate bumping into that hump everytime I try to slide back on the seat.
Old 07-26-2017, 10:23 AM   #11
Mudflap   Mudflap is offline
Instead of staples I use 1/4" long sheet metal screws. Easier and seems to hold up just as well.
