Old 11-25-2017, 12:21 PM   #1
Angus67   Angus67 is offline
Angus67's Avatar
Idle mix stack up
So i cleaned out my pz27 carb on my 200gy, got it all back together, but when i put the idle mix scew back in, i only had the screw. So i put it in, 2 turns out
Now that it back on the motor and full of gas, a small drop forms on the mix screw. Most other carbs I’ve worked on has a small spring and rubber (?) washer.
I may have blown it into another dimension with 150psi of air.
Just to confirm. Its oring , spring, mix screw?
Could this also cause hunting idle? The rubber carb mount is pretty cracked up, so that is more likely the issue there.
2006 roketa 200cc
1971 Yamaha xs650
2x 1980 xs650, 1 is a café, other is a chopper/brat
1972 Honda xl250
2x early 90's Honda rf600 parts bikes
more mc junk laying around.
Old 11-25-2017, 01:34 PM   #2
Ariel Red Hunter's Avatar
First of all, subjecting the carb to 150 lbs of air pressure is not smart. Secondley, you will never get anything even remotley approaching decent, REPEATABLE results with vacuum leaks on the engine side of the carburetor. First thing to do is to replace that rubber carb mount....ARH
Old 11-25-2017, 03:33 PM   #3
Angus67's Avatar
Thanks
2006 roketa 200cc
1971 Yamaha xs650
1972 Honda xl250
Old 11-25-2017, 03:58 PM   #4
Your order is correct, although usually there is a small metal washer between the O-ring and the spring to prevent the spring from catching and binding up the O-ring when you turn the screw.
I agree with fixing the carb insulator/boot/intake before any further trouble shooting. That said, yes a leaking idle mixture screw could potentially cause a running issue. More importantly, a safety issue lol.
Old 11-25-2017, 04:54 PM   #5
Angus67's Avatar
thanks dan. I pulled a spring, o-ring and washer from a 1980 -84 Yamaha xs 650 carb and went right in. no drips.
this is not my first rodeo with carbs. I always blow them out with hi pressure air. maybe not 150, but im sure that other dimension dosnt exist either, and if it does, its full of socks that don't match.
Ill order a new boot.
2006 roketa 200cc
1971 Yamaha xs650
1972 Honda xl250
Old 11-25-2017, 05:39 PM   #6
humanbeing's Avatar
The O-ring trick: http://www.motorfans.com.cn/forum.ph...authorid=75082
Old 11-25-2017, 06:45 PM   #7
Angus67's Avatar
Wow. Had no idea. Now i know where to get new ones. Thank you human being
2006 roketa 200cc
1971 Yamaha xs650
1972 Honda xl250
