08-07-2021, 05:10 PM | #1 |
Fuel valve question
Page 7 of my 2020 hawk deluxe manual Says . On- gas can flow to the nozzle
Off - gas can’t flow to the nozzle Res - gas can flow to the nozzle you you have run out of gas in the tank So there is a on , off ,, reserve on this bike , I can’t find a conventional valve on my bike Last edited by weiser23; 08-08-2021 at 05:01 AM. |
08-07-2021, 08:57 PM | #2 |
They probably recycled that part of the manual from the regular Hawk.
08-08-2021, 11:15 AM | #3 |
There is not one on my DLX either!
08-08-2021, 11:38 AM | #4 |
I guess that solves the clogged petcock theory.
08-21-2021, 08:35 PM | #5 |
Why don’t the hawks have a reserve on its gas tanks
08-21-2021, 09:01 PM | #6 |
My carbureted hawk has reserve setting on the petcock and it works. The fuel injected hawk dlx has a fuel pump in the tank.
08-21-2021, 10:51 PM | #7 |
Petcocks work fine with gravity feed systems but when you put pressure on them from an in-tank fuel pump there will be problems.
There is also the thing about a fuel pump not needing to push on a blocked source when someone fails to turn on the petcock at startup.
