Greasy rear tire
Do y'all have issue with grease with the chain getting flung onto the side of the tire? I took the chain off, bathed it in hot gear oil for, hung it up overnight, and reinstalled the chain the next morning. There is oil on the side of the tire, and if I lean hard into a turn, I'm sure to lose a lot of traction.
Try one of the clear fast drying chian lube sprays. No mess.
Ok my bike is a cb350 but my question is on topic I think. I keep my bike insanely clean, and I don't use water when I wash, I polish it up. I wanted to get an o ring chain cause it reduces chain muck flying off after a chain lube. I'm changeing out my sprockets but won't be able to afford an o ring chain just yet, but I can come up with the cash for a good roller chain so it's back to having to deep lube the chain. I've used fast dry lube sprays and even chain wax, with simular messy results.
Question: What is a good chain lube, that is also a clean chain lube? P.S. On a cb, if you remove the chain you have to take off the clutch push plate to get the chain back on. It's a pain. I'd like to lube the chain without taking it off( most times). All input is welcome. ![]()
IronFist ___________________________________ The "chain" of command is used for beating spammers. ___________________________________ |
This is what I use. 100% mess free!
http://www.cyclegear.com/spgm.cfm?L1...63_G&tier2=272 Used it a few years no without issues. |
After you lube the chain, wipe it off with a rag. The excess on the outside of the chain isn't doing any good anyway. Don't do what I say next, but I throw the bike up on a stand, fire it up in first gear and hold a rag around the chain as it spins. Clean as a whistle afterwards, and only a moderately high risk of loss of limb 8O .
#6 | |
I use this on all of my motorcycles.I spray it every 300 miles or so.No Mess at all.
http://www.maximausa.com/products/ch...s/chainwax.asp
Kman 2007 HI-BIRD 250 2007 Vbike V4S 250 |
CRidin; I'm on dial up and can't open that link. Please just describe it, thanks.
kczukiman: I just cleaned 36years of that stuff out from my clutch push/sprocket cover. Well, not that wax, maybe that product is better, I'll give it a shot, thanks. The stuff I used did flick off after a while. Also, I don't know how much gets into the chain rollers and how much wax just sits on top of the chain? red2003: " Don't do what I say next, but I throw the bike up on a stand, fire it up in first gear and hold a rag around the chain as it spins. Clean as a whistle afterwards, and only a moderately high risk of loss of limb " Yes, I would never tell someone to do that! ![]() ![]() Thanks red, sometimes it feels good to have someone tell me I'm on track. No one here to show me the tricks to doing the job right. N2r.
new2riding,Iv'e been using it for about 5 or 6 years and no mess.Even on my first bike 1978 cb750k .
#10 | |
Here ya go. MotoPro Chain Lube uses the latest technology to create a unique concept in chain lubrication. When you want your chain to run cooler, smoother, and quieter - and last longer - use MotoPro Chain Lube. Features and Benefits Fast-drying, nearly-transparent film actually seals the chain Rich in PTFE fluoropolymer resin and MOLY, two compounds that provide unequaled lubrication Great on both O-ring and standard chains On O-ring chains, the elastomer is conditioned and protected from deterioration and cracking, preventing premature wear Solvents evaporate quickly, unlike traditional "sticky" chain lubes, leaving a flexible, dirt- and water-repellent protective film that won't fling off Provides long-term protection against rust Dye-free formula won't stain white paint |
#11 | |
I haven't had any luck with the spray chain lubes that are supposed to be mess free. What I found is that they don't get inside the rollers. I use the gear oil soak.
One method that seems to work pretty well is the parifin wax soak. A lot of bicyclists use it. Using a double boiler so you don't start the house on fire, melt enough wax so you can immerse the chain in it. Use the kind of wax used in canning or candle making. Let the clean chain soak in the hot wax for a while, stirring it around occasionally so the wax gets into the rollers. Hang the hot chain and let the excess wax drip out. Once cooled and dried, brush off excess wax on the exterior of the chain with a wire brush. Q |
#13 | |
"Strange rash of people losing fingers involving Chinese-made motorcycles, when we return." |
#14 |
This is what a bicycle sprocket can do to your finger. 8O I imagine a motorbike sprocket will eat up your entire hand.
#15 |
8O Ya. Maybe wiping the chain, rolling the bike forward, wiping the chain, rolling the bike forward method would work just fine. 8O
