Old 06-13-2008, 06:24 PM   #1
Trebek   Trebek is offline
Clutch slipped after oil change
I changed my oil yesterday and for the first mile (uphill mostly) the clutch was slipping then grabbing then slipping some more. It was strange.
After a couple miles the clutch was normal and I went on a pretty steep ride up into the mountains (see my ride report with pics!) and the slippage thankfully was a thing of the past.
I put generic Wal-Mart 10w- 40 in the bike. Was planning on changing it out and putting 5w-30 for my next oil change. The bike only has 65 miles on it but considering how nasty my 50 mile oil looked, I'll probably change it to the thinner stuff real soon.
Old 06-13-2008, 06:38 PM   #2
Guest
Posts: n/a
it is summer time and these are hard working little engines, are you sure a thinner oil is a good idea?
Old 06-13-2008, 08:00 PM   #3
Dragon   Dragon is offline
I hope you're not using the "Energy Conserving" stuff from wally mart.
Chinabikeless
Old 06-13-2008, 08:09 PM   #4
AZ200cc   AZ200cc is offline
I only use good oil, It is always cheaper than a new motor... Valvoline makes oil that is meant for wet clutches...Pay more now buy less parts later
<br />2001 Suzuki DR200SE<br />1997 Suzuki RM250 YIKES<br />1995 Yamaha Breeze 125 daughters<br />1991 Honda XR80r Restored<br />maybe a 2003 Yamaha TTR90
Old 06-13-2008, 10:46 PM   #5
IronFist   IronFist is offline
I was using 10/40
My gear shift was sticking, and my clutch is adjusted correctly. If I go to a thinner oil I think my gaskets will weep again. I got some 20/50 tonight and I'll give it a go tomorrow. I had to switch back to dino oil(gaskets). I'm using Canadian Tire oil for 4 stroke motorcycles. I don't think going to a heavier oil will hurt the bike too much now that it's warm out. If I don't shift better I'll dump it and try something else. $6.50 per test, no big deal.
IronFist
___________________________________
The "chain" of command is used for beating spammers.
Old 06-13-2008, 10:54 PM   #6
doesn't Hi-Bird recommend 5 w30 ? correct me if I'm wrong before I put this stuff in it tomorrow/
Old 06-13-2008, 11:02 PM   #7
I believe it's been posted that 5 w30 only come in synth and synth shouldn't be used for break in. (Kato I think..)
For myself, 5/30 sounds like snowmobile oil. Even the synth I used didn't have a 5 in it. I bet it's great if you start your bike a lot. But I'm no oil pro. I'm sure others will help you on that.
http://www.chinariders.net/modules.p...t=4721&start=0
Here is the other oil thread that is also current. It talks about 5/30. Hope it helps.
IronFist
Old 06-14-2008, 10:14 AM   #8
katoranger's Avatar
I tried 5w30 semisyn and it was fine, but the engine was noisier.
The only thing to make sure of is to watch out for the "energy conserving" label.
I use walmart oil in my jeeps for years. No problems.
Allen
Old 06-14-2008, 12:00 PM   #9
red2003   red2003 is offline
5w30 oil is fine. Don't worry and don't believe the motorcycle oil hype designed to get you to pay Honda $10.00 a quart for their "special moto oil". 5w30 car oil is fine. You will need to change it out often as it will break down quick in a bike. I have been running 30 weight oil for over 2000 miles in my Roketa. Starts easier, runs cooler and gets MUCH better mileage and has better power. Next oil change I would go to a 10w30. It will not break down as fast. I change out my oil as soon as it get dark in the sight glass. Usually less then 500 miles. Your clutch slip right after the oil change is normal. My Roketa always slips for the first 10 - 15 minutes of riding after an oil change.
Old 06-14-2008, 12:14 PM   #10
dr1445   dr1445 is offline
shell rotella 15-40w at your local wally world. i just bought a jug [1 gallon] for $9.72. it's rumored to be the good stuff for 4 strokes sharing engine and transmission oil.
Old 06-14-2008, 01:18 PM   #11
katoranger's Avatar
The shell works fine. I have been using it. I bought a case of suzuki 10w40 oil for $15 of craigslist so I will use that up next. I couldn't pass up that deal.
The 5w30 oil worked fine in my bike too.
Red is right about changing it often. I go 500-1000 miles usually and I am due right now. It is about every 3 weeks for me.
Allen
Old 06-14-2008, 01:19 PM   #12
thanks Red, I'm relieved to know this is normal. It only did it the first 2 miles and hasn't since. I'll switch to the 5-30 (since I got it) it's still pretty cold here. Since I'm riding here quite hard, I'm changing my oil every 50 miles until it starts running clean.
Old 06-14-2008, 08:16 PM   #13
justinkr58   justinkr58 is offline
has anyone tried transmission fluid in there bikes?
that seems to have a good viscosity and lasts 20000 to 40000 in a car..
or am i an idiot
Old 06-14-2008, 08:56 PM   #14
katoranger's Avatar
Trans fluid is not designed to be a motor oil. It is more like a hydraulic fluid.
I would not put it in my bike. It does work as a fork oil.
Allen
Old 06-14-2008, 09:16 PM   #15
Guest
Posts: n/a
The 5-30 comes in regular oil, The 5-50 is full synthetic only....
