Old 11-17-2009, 11:02 AM   #1
Dragon   Dragon is offline
broken spokes
How many broken spoke is too many? I've been riding around with two. None of the local bike shop carries any individual spoke. They want me to order a whole set for a hundred bux.
Chinabikeless
Old 11-17-2009, 11:29 AM   #2
Cal25   Cal25 is offline
Is this on your HiBird or Lifan? If it is the HiBird I would suggest saving the head ache trying to get a spoke that will fit and send a sample to Buchannons Spokes. Order 4 or 5 so you have a couple of spares. Should cost you less than 20 bucks.
Thats what I did after spending alot more for spokes that did not fit. Turn around time was less than a week.
Old 11-17-2009, 11:58 AM   #3
lego1970   lego1970 is offline
I wouldn't be too worried about two if your not doing a lot of hard braking, quick accelerating, severe leaning, and hitting jumps however each one plays a role, so I wouldn't put it off to long. Good luck.
Old 11-17-2009, 12:10 PM   #4
Fix it. The fewer spokes beaing the load, the more likely more will fail. Motorcycling is dangerous enough so anything you can do mechanically to improve your chances should be done.
